What Springs Came on my '00 SS? 1LE?
Everything I have read is that the '98-early '00 SS's came with firmer (firmer than standard Z-28) Decarbon shocks and 1LE springs. Sometime during the 2000 model year, it was changed to firmer Decarbons paired with standard Z28 springs.
I am trying to determine what springs my SS has. My vehicle was built on 1999-09-28. If it helps, here's the build list:
RPO Description
UA6 THEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
UL0 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,AUTO TONE(UL0)
U59 SPEAKER SYSTEM 8, QUAD FRT DR MTD, QUAD SAIL PNL, AMPLIFIER 8 SPKR AMPLIFIER(U59)
U73 ANTENNA,FIXED FIXED ANT(U73)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
V12 COOLING SYSTEM,POWER STEERING FLUID P/S CLG SYS(V12)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
WU8 SALES PACKAGE CAMARO SS APPEARANCE AND PERFORMANCE CAMARO SS APPEARANCE & PERFORMANCE PKG(WU8)
Z28 PERFORMANCE PACKAGE,SPECIAL PERF PKG(Z28)
SPECIAL PERFORMANCE PACKAGE,(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(Z28)
1SB PACKAGE-OPTION 02 (1SB)
1SZ PACKAGE OPTION- (1SZ)
11Q MOLDING COLOR,PEWTER (11Q)
11U EXTERIOR COLOR,PEWTER MET (11U)
EXTERIOR COLOR,PRIMARY (11U)
19I INTERIOR TRIM COLOR (19I)
INTERIOR TRIM,BLACK (19I)
INTERIOR TRIM,EBONY (19I)
192 TRIM COMBINATION,BLACK LEATHER (192)
41T VINYL TOP COLOR,BLACK (41T)
6ZM COMPONENT FRT LH COMPUTER SEL SUSP (6ZM) SUSP(6ZM)
7ZM COMPONENT FRT RH COMPUTER SEL SUSP (7ZM) SUSP(7ZM)
8TJ COMPONENT RR LH COMPUTER SEL SUSP (8TJ) SUSP(8TJ)
9TJ COMPONENT RR RH COMPUTER SEL SUSP (9TJ) SUSP(9TJ)
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE PASS SI INFL RST SYS(AK5)
RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
BBS **** SHIFTER HURST HURST SHIFTER(BBS)
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
CAE HANDLING CHARGE - GM ST THERESE TO SLP LASALLE QUEBEC FOR UPFITTER CONVERSION (VTIMS)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
FE4 SUSPENSION SYSTEM SPECIAL RIDE & HANDLING SPECIAL SUSP(FE4)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IP2 TRIM,INTERIOR DESIGN (IP2)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K43 GENERATOR 102 AMP 102 AMP(K43)
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
MM6 TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D 6-SPD M/TRANS(MM6)
MN6 TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NW9 TRACTION CONTROL ELECTRONIC ELEC TRACTION CONT(NW9)
N73 WHEEL,CUSTOM SPORT MAGNESIUM WHL(N73)
WHEEL,CUSTOM SPORT PAINTED AL WHL(N73)
PBT TEMPORARY HOOD FOR UPFITTER DELIVERY
QFK TIRE ALL P275/40ZR17 93W BW R/PE ST TL HW4 TIRE(QFK)
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
T82 HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82)
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
RPO Description
