Replace my pro-kit with........?
I have an iron block, and it sags in the front with the LS1 eibach pro kit, even with the hose mod in the rear.
My first thought was to just use the LT1 equivalent in the front and keep the rear springs, but the rear springs are way too soft. even with adjustable shocks, i have to keep 5-10psi in my air bags to keep from hitting axle to body under normal driving conditions.
What complete set should i get to replace it?
1. The car will be road-race or autocross oriented.
2. No drag racing.
3. I don't mind a relatively rough ride, as long as it doesn't dive or give much.
4. Can't afford coil-overs.
2. No drag racing.
2. No drag racing.
2. No drag racing.
That being said with your more unique situation you may want to try different springs rates from ground control to see what suits your needs best.
If you want a "starting point" Id suggest the koni/strano setup as it has multiple national SCCA wins to back up that it actually works.
LS1Tech Premium Sponsor
I'll have to agree that the weight on the nose could present a problem, but you can work with it - just have to keep it on your mind.
If your budget doesn't allow for a new setup and you want to raise the nose a little, why not try our shock spacers? This will bring the front of the car up approximately 1/2-inch. They're cheap, and we sell them to a lot of people looking to correct similar issues with Eibach springs.
- Kevin
- Kevin
- Kevin
- Kevin
so i may try out the strut spacers with the pro kit and see if that makes enough of a difference. if i keep the same springs and correct the sagging issue, i may be able to afford a complete set of koni's to replace the AGX set i have now.
