fuel supply line size
Old 03-18-2013, 06:21 PM
sixty4sedan's Avatar
Default fuel supply line size
Im installing a 5.3 with just a cam and ls6 intake/injectors into my nova and was wondering what would be the necessary size for fuel supply to the engine? Im running a walbro 255 with a corvette fuel regulator. Im thinking that Im going to be at a -6 but Im not sure if that will be enough..... can anyone chime in and lend a hand? Thanks
Old 03-18-2013, 06:30 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
-6 is fine.
You can also go -8 if you want for only a few $$ more & it will be up to the task if you ever crank up the power at a later date.
Quick Reply: fuel supply line size
