car has tons of bite cornering but is very darty
ok let me explain what i have going on here. i swapped over a 2001 camaro convertible from a v6 to v8. it has an L33, 4L60E, 3:42 rear, panhard relocation kit, on car adjustable panhard, bmr torque arm, bmr 1" drop lower A-arms, PA racing k member, BMR strut tower brace, eibach 1.5 drop springs in back, stock v6 springs up front, stock v6 rack 2.5 turns side to side.
ok so the car handles great. taking clover leafs around 95 with no tire squeeling, sliding or anything and you can tell the car can handle alot more going into the corners. however when your going straight, the car is very sensitive to the slightest movement. once you feel it i'd relate it to how a crotch rocket feels when it starts getting that high speed shimmey.
i haven't scaled the car yet. i'll try getting that done this weekend. so what are some suggestions? thanks
- Scottie
- Scottie
- Scottie
- Scottie
My car feels kinda shaky and wobbly at high speeds, anything over 80 and I lose immense amounts of handling.
Zo6 knock offs stock size. nitto 555 245/50/16's . they car has tons of grip once you get into a corner. it's the over sensitivity when your going straight and barely move the steering wheel. light movements on the steering wheel have a big effect the cars balance or sway. you can feel the rear end follow aggressively (not loose) which makes me think it's in the front end.
I am thinking alignment too. I have mine set rather aggressively (forgot the specs) and it is a little darty in a straight line. I will take the trade off for cornering though.
i had new tie rods put on and had it aligned when i got the exhaust put on. i'm gonna run the by the shop and have them check it again.
