Couple quick oil related questions
Old 03-19-2013, 08:36 AM
oscs's Avatar
Default Couple quick oil related questions
1: what is the easiest place on the lq4 block to get a oil temp reading for my autometer guage.
2: what are some normal oil pressures I should be seeing from an lq4 in various rpm ranges
3: the motor is reaching 100k what is your suggestions on motor oil weight?
Old 03-19-2013, 11:16 AM
oscs's Avatar
I'm also curious if the standard autometer temp sending unit will thread into the t56 somewhere easily.
Old 03-19-2013, 08:24 PM
oscs's Avatar
anyone?
Old 03-19-2013, 11:27 PM
3rdCoastPowerSports's Avatar
You could remove the galley plug on the lower driver side near the timing cover, put in the correct thread size plug and then screw in your 1/4" temp sender.
5w-30 high mileage (apparently has some additives that are supposed to help out with a more mature motor)
Quick Reply: Couple quick oil related questions
