Which MLS head gaskets for 4.030" bore? 4.040" or 4.100"?
Old 03-19-2013, 07:40 PM
kgkern01's Avatar
Default Which MLS head gaskets for 4.030" bore? 4.040" or 4.100"?
As the topic states, which head gaskets are best for a 4.030" bore? Running around 13.4 cr and E85.
Old 03-19-2013, 07:49 PM
I need a gauge for that
Atomic's Avatar
You dont want the gasket to be smaller than the bore, so 4.040"
Old 03-19-2013, 07:50 PM
Blackbirdws6's Avatar
Old 03-19-2013, 07:51 PM
kgkern01's Avatar
Well neither is smaller than the bore, one is .010" larger and the other is .070" larger. I want to know if the 4.040" would be too close to the bore size?
Old 03-19-2013, 07:59 PM
9-Second Club
Ed Wright's Avatar
Depends on how well your bores, the head gaskets, and your dowel pin locations. Unless your block is CNC machined (not many are) you would be safer with 4.1" gaskets. That is what most everybody uses. Your talking .005" radial clearance with the 4.040" gaskets.
Old 03-19-2013, 10:39 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
yaaa what he said!
Old 03-20-2013, 12:27 AM
Atomic's Avatar
For some reason I read that as 4.040 or 4.010
so yea, go for the 4.1s
Old 03-20-2013, 07:51 AM
quik95lt1's Avatar
what ed said x2
on a run of the mill combo id want at least .030 so .015 radial on each side......I run a 4.075 on a 4.0465 bore on mine, its as tight as I felt comfortable going with a stock block and stock dowel pins my $hits nothing special in that area
Old 04-18-2013, 06:34 PM
kgkern01's Avatar
The block had to be taken .040" over, and square decking ended up at .002" deck. Would a .042" quench be too loose or should I pay for custom Cometics at .035" to get it to a .037 quench?
Old 04-20-2013, 11:39 PM
cardo0's Avatar
Default Nice quench hieght.
Thats right were it should be. Though .037" is better u won't have to compromise with a thinner and more costly head gasket and will still have great quench.
0.042" will get u good quench and use a good head gasket too.
I wish my car had 0.042" quench.
Hope this helps,
cardo
Quick Reply: Which MLS head gaskets for 4.030" bore? 4.040" or 4.100"?
