How Easy to Install Input Shaft Bearing?
I was wondering if there's a writeup on replacing the bearings in the T56 tranny. I've searched but havn't seen one. Any help? or if someone could tell me what it takes to install new ones
i got the 1st and 2nd battle covered, its the 3rd im worried about. I've never done it and dont wanna mess it up. Do they sell a bearing driver tool at a auto parts store? or would u need a press?
Here are a few to look at. Most guys use a socket and extension which works fine, but as you've not done one yet, I'm reluctant to offer this as advice.
The Tremec teardown pdf is downloadable. ls1tech.com/forums/manual-transmission/510788-manual-transmission-faq-look-here-first.html
The input shaft has two bearings supporting it and you should make sure they need replaced as well as re-shim when replaced. Most of the trans needs torn down to do that.
