help, broken valvespring=bent valve
anyone done this? driving hard when valvespring broke. pulled head off and piston was hit on top right from center of piston to 1/4 inch from edge of piston. didnt see any cracks. bent a valve.
Yes, definitely replace all springs... I broke one and the retainer caught it. I didn't have the money or time to replace all of them so I just replaced the one. A few weeks later I broke another one, retainer broke as well and bent the valve all to hell. Lesson learned... the hard way.
Originally Posted by Beast96Z
It's a stock bottom end A4.
Originally Posted by slick98ta
I had a few valves hit stock pistons pretty good.All is fine,like said above just make sure you get rid of any sharp edges.Here's a pic of what mine did.
Todd, if there seems to be no physical damage such as cracks or anything, I'd put her back together. I would reccomend changing the springs, preferabally a good set of duals. That would help from this ever happening again. You can always do a leak down when you get it back together to make sure.
