what is this part called
Old 03-20-2013, 11:48 AM
chopperb's Avatar
Default what is this part called
In need help identifying this part. I lost the one on the right side. 2000 camaro z28 convertible.
Thanks
Old 03-20-2013, 12:11 PM
Formally Simplɘ Jack
BoricuaHec01's Avatar
Sail panel covers.
Old 03-20-2013, 12:14 PM
chopperb's Avatar
Thank you
Old 03-30-2013, 11:39 PM
Wicked 94TA's Avatar
Yep and if you need some and have a pick and pull yard in your area they're pretty easy to get off. Get about a 1" putty knife and start prying it off but very carefully. I put it under an edge and used the butt of my hand and carefully hit the butt of the putty knife going in some and pulling it out and moving up and down to different areas. Its held on with the same kind of tape/adhesive the emblems are. Take your time and you can get them off in one piece. Heat helps a lot too if you have that as an option.
Old 03-31-2013, 08:01 PM
crazyelf's Avatar
They are called an applique panel
http://www.trademotion.com/parts/199...plique%20panel
Quick Reply: what is this part called
