need quicktime bolts
Recently purchased a used QuickTime rm-8020 and it came without bolts. I called QuickTime/prestolite and they didn't have any in stock and couldn't tell me the sizes.
Does anyone know the sizes & quantity by any chance? It looks like a mixture of metric and grade 8 bolts by the pictures I've seen. I still have the OEM bell housing and transmission bolts so I'm not sure if those will work.
OEM bolts will work, except for a couple of the BH to engine bolts, clearance will be tight, where QT use cap screws in the two crank centreline positions.
The T56 holes should be metric the same as OEM. Although on my early unit, for some reason the numpties had it tapped imperial, which was bloody annoying.
Although, Ive a funny feeling I remember cutting down the OEM BH bolts a little. I did not use the aluminium plate against the engine though. I bolted the BH directly to the engine.
Dont even know how they expected that plate to fit at all.
