Help picking a good off the shelf cam
Old 03-21-2013, 02:06 PM
FormulaTA96's Avatar
Question Help picking a good off the shelf cam
So Im pretty much done buying all the parts for my 383 build and Im down to picking a cam..Im currently thinking about buying a cc503 off of someone,mainly because it has a pretty good power band and is very streetable..But I thought I'd ask you guys for some opinions..I want something that is streetable,but will still make some mean power with my setup..My car isnt a DD but it's out frequently in the summer..I was considering a cc306 but I've heard the power really only comes in up top and its not too streetable..
Specs of my heads..
60cc combustion chambers
205cc intake
70cc exhaust
2.02 intake valves/1.60 exhaust
I have springs good up to .600 lift,and 1.6 pro mags NSA..
Thoughts?
Old 03-21-2013, 02:42 PM
WS Sick's Avatar
Everything about powerband pertaining to a 350 will not translate over to the 383.
The 306 in a 383 will act much differently than in a smaller cube motor. The 503 IMO is too small unless it's just a complete driver, meaning that you dont plan on going fast.(in a 383)
Old 03-21-2013, 03:34 PM
96z28_lt1's Avatar
i enjoy my xfi280, strong mid range and top end power, nice little lope to it.... but mines is a stock short block.... i've read its very streetable though on 383 builds...
Old 03-21-2013, 04:47 PM
Ohh trust me,I plan on going fast in it lol..I think I'm just going to go with a cc306 then..
Old 03-21-2013, 05:13 PM
Village Troll
SS RRR's Avatar
It is if it's geared correctly.
Old 03-21-2013, 07:57 PM
supernaturalta's Avatar
You can do better than that. There's a number of board sponsored vendors who you could contact who will get you what you need.
Old 03-21-2013, 09:42 PM
LT11996's Avatar
A Lloyd Elliot cam spec'd for your set up would cost the same as a new cc306 cam and be way more efficient for what you want. Why not do that?
Old 03-21-2013, 10:25 PM
1961ba427's Avatar
I'd go custom OR xfi280
Old 03-21-2013, 11:03 PM
speed_demon24's Avatar
Where can I get one of those 116mm throttlebodies?
Old 03-21-2013, 11:49 PM
jstrong's Avatar
I have a really good cam for that build new in the box never used just orderd it and went a different way. here are the spec.
dur@ .006 IN.276 EX282
dur@ .050 IN224 EX230
lobe lift IN.340 EX.340
valve lift IN510 EX510 @1.5rr so 550 with 1.6rr
in C/L 104 IN. open 34 IN. close 62@.006
ex. C/L 116 EX. open 77 EX. close 25@.006
lobe separation 110
seat press. 110-120
open press. 310-320
this cam is from Steve Demos @ Demos cams
Old 03-22-2013, 02:23 PM
lmao its just a twin 58mm bbk..i mean two 58mm holes do equal 116mm lol..i just put that to sound cool tbh lol
And thanks for the cam offer,but thats a little too small for what Im looking for..Also guys how much do LE's custom grinds usually run? Im actually looking at getting a Lunati Voodoo 60122..The asymmetrical lobes of the Voodoo line are niiice.
Old 03-23-2013, 02:43 AM
With all due respect, two 58mm holes do not equal one 116mm hole in area and air flow.
to find the area of a circle:
area = pi times radius squared.
(pi)(29^2) = 2642mm^2 area for one 58mm bore, 5284mm^2 area for two 58mm bores.
to find the diameter of one circle with an area of 5284mm^2:
((square root of (area/pi)) times 2 = diameter
((square root of (5284/pi)) times 2 = 82mm diameter
Therefore, a twin 58mm throttle body will flow about the equivalent of an 82mm single bore throttle body.
Quick Reply: Help picking a good off the shelf cam
