Help with oil pan selection 1968 ls1 camaro
Old 03-21-2013, 11:00 PM
souljaboy9768's Avatar
Default Help with oil pan selection 1968 ls1 camaro
Need help picking an oil pan for my 68 Camaro. I've read a little on the autokraft pan but it seems so people had to tap and drill an extra hole for oil pan. Wondering if anyone ran into that problem.
What options do I have for oil pan? Pics would be nice
An if you happen to have one for sale let me know also.
Right now I have a stock fbody pan from my 02 camaro
Old 03-22-2013, 04:00 AM
BobKovacs's Avatar
The Holley pan is your best bet- tons of center link clearance and ground clearance.
Old 03-22-2013, 08:30 AM
HexenLord's Avatar
I went with the holley pan. It was Autokraft, Holley, or Mast. I'm not a fan of fabricated pans since they don't provide much rigidity and some of them have sealing issues as the flanges often warp during welding.
Old 03-22-2013, 08:43 AM
88Fbody6L's Avatar
Holley pan here too. Great fit with plenty of clearance to the steering arms
Old 03-22-2013, 09:29 AM
I've been looking at the Holley pan also. Looks like it's a complete kit minus the gasket
What you opinion on the GM retro fit pan?
Old 03-22-2013, 09:56 AM
bczee's Avatar
Are you referring to the GM Muscle Car pan/kit ?.. if so. .IMHO, NO, I would not recommend it. It hangs to low.. even lower than a CTS-V pan
If cast...go with a notched F-Body pan, Holley or MAST pan.
If fabricated ... Autokraft, Many of the steel fabricated pans will need remote oil Filter setups.
I had a CTS-V pan on my Chevelle, had to take it out a few months ago. Bottomed out on it and cracked it, just hung to low for a lowered car. Now have a Notched F-Body pan. I have a Holley on my Nova. As noted, would recommend this one for 1st Gen F-Body / 3rd Gen X... (same subframe).
BC
Old 03-22-2013, 11:26 AM
HexenLord's Avatar
The GM muscle car pan is just an LH8 truck pan. The sump is short enough that it clears the subframe, but its also 8 inches tall and hangs about 2 inches below the subframe. If you bottom out, the first thing that hits is the pan. F body pan is shorter and doesn't have this problem as much but won't clear the subframe without notching it. The holley pan clears the subframe and steering arms, and is only about 5 inches tall so it won't hit the ground. Its cast so it provides a little extra torsional rigidity. It fits like a stock pan. Mast is the other cast option but its 100 more than the holley pan. I haven't seen it to judge quality, but I didn't have any issues putting my faith in holley.
Old 03-22-2013, 12:36 PM
I have an fbody pan on my ls1 now. Where can I get it notched cheap?
Old 03-22-2013, 01:18 PM
Javadude's Avatar
souljaboy9768, I have 68 Firebird and same dilemma with the oil pan, what engine mount are you using?
I saw Moroso oil pan 20140 for $250.00 would it fit 68 Camaro/Firebird without mod?
Old 03-22-2013, 02:25 PM
bczee's Avatar
For $250.. you get the pan.. you will also have to spend some more on a remote Oil Filter setup.
Not many options on getting a pan notched on the Cheap.. I would not let a 1st timer do this.. they usually end up leaking.
Get a good Welder to Tig it... many of the older pan are hard to weld due to the Oil being in it so long and using cheap aluminun cast. They need to be throughtly cleaned.
I had one pan that 3 different good Welds just couldn't do it for one reason or another. One of them does Aluminun Transmission cases all of the time.
S&P offers this services.. but I think it is like $250 ?
Holley and Mast one just about fit anything.. Autokraft is a good one too as a steel fab'd one.
BC
Old 03-22-2013, 02:44 PM
Mizzouri's Avatar
Amazon, of all places, has the pan reasonably cheap:
Holley 302-1 GM LS Retro Fit Engine Oil Pan : Amazon.com : Automotive Holley 302-1 GM LS Retro Fit Engine Oil Pan : Amazon.com : Automotive
I'm still considering the S&P modified pan in to my 68. Does anyone have experience with the Holley pan and road course usage?
Old 03-22-2013, 02:56 PM
Gray86hatch's Avatar
Holley pan is a good piece. We put 8000 miles on 1 last summer. A truck pan is going to hang too low.
Tim
Old 03-22-2013, 03:28 PM
Looks like Holley is the choice to go.
Is it better to go through jegs or summit in case I do have issues with missing items or ??
Old 03-22-2013, 03:29 PM
By the way I'm running a Chris alston chassis g machine subframe
Old 03-22-2013, 05:35 PM
Doug G's Avatar
Stock sub frame, 1.5" setback mounts, holley pan....1/8" -3/16" off the crossmember and everything looks to clear.
Old 03-22-2013, 07:30 PM
Javadude's Avatar
What mount are you using to get 1.5" set back?
Old 03-22-2013, 07:41 PM
Doug G's Avatar
Or are these 1" ??? Sorry for the confusion...Look like these.
http://www.ebay.com/itm/LS-LSX-Engine-Swap-Adapter-Plates-Engine-Mounts-1-Set-Back-4-8-5-3-5-7-6-0-6-2-/330858294543?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d08b0ed0f&vxp=mtr
Quick Reply: Help with oil pan selection 1968 ls1 camaro
