Racetronix 44lb injectors, B&B,317's, magnavolt, posi, bumpers, etc
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NJ
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
New SJM Line Lock Kit. $100
B&B catback- Exhaust is in good shape, muffler is nicely polished, no tips. No pics of Ipipe at the moment as I havent grabbed it out of storage yet $300
SLP 3.5" slash cut tips. Tips are scuffed a little but can be polished. They are both still perfectly round with no dents. I will also include clamps. $90
Eaton 10 bolt posi, 3 channel(can be used in 4 channel cars as well), series 3?(whichever comes with a 3.42 gearset).
This posi looks next to new. It is, however, missing the center shaft and retainer bolt. This can be had from Eaton $150
Stock 3.42 gears. Pulled at 50K in good shape, were very quiet on accel/decel when removed. Don't have pics of pinion gear but it is also in good shape. $60
Black Hurst stick. $40
Instrument gauges with RK Sport flame gauges. Includes all parts pictured. I swapped the face for a firebird face and bezel. I was told the odometer reading was 76k, but have not verified. $50
317 heads- Was going to use these since I am going FI but I think I am going to retain high compression since I'll be running low boost. Complete with valves, valvesprings, rockers etc. Can bolt them on and go. Had 70k miles when pulled $150
Magnavolt that came with an Fbody Magnacharger kit- $100
Torsen Differential, 3 channel(can be used in 4 channel cars as well), series 3?(whichever comes with a 3.42 gearset). Guy I bought it from said it had 15k miles when he swapped a 12 bolt into his car. SOLD
3 Channel backing plates with e brake shoes. Had 30k when removed. $100
LT1 Driver side tail light in good shape. $30
T Top shades- Grey. $20
Ebony seat belt guide. IIRC, its the passenger side $5
I also have a front and rear bumper along with the crash bars from my black 01 SS for sale.
The front is pretty beat up, has a 4 inch crack where it says Camaro, not noticeable with a grille on it but has decent scuffing near the headlight and spiderwebbing, along with a half inch crack near the driver side sidemarker. Should be easy for repair and repaint. Honestly really only putting this up here in case someone got into a crash and needs something to throw on quick or wants an OE bumper to avoid fitment issues $40
Rear has a little spiderwebbing and has a scuff that should come out for the most part. $100
Impact foam bars are both in good shape, $50 each
Exhaust is an SLP LM1, tips are the 4 inch singles in ok shape. All still together cause I'm having a hard time separating the over axle pipe, probably needs a little heat on it to slip loose. SOLD
Have an air pump as well, came off at 80k, includes bracket. $20
Black Header Wrap. I believe this is 40 feet. $20
American Legacy 8" subwoofers. 800 watts. Was gonna use these for a small sub box at the bottom of the trunk but decided I didn't need a trunk. $40
2 Bolt exhaust flanges. (1) 2.5", (2) 3". All brand new, one 3" flange removed from packaging. $15 each
Brand New 5.25" Alpine Type R Component Speakers. $125
I will take trades for 60lb injectors, ls7 lifters, trunion upgrade, etc.
Not sure on miles, got it used with my maggie setup. I'd say under 10k since thats what is on the blower.
Not sure on an exact price, but it was about $65 for shipping to somewhere in Cali so I'd say $200, the 317's are pending at the moment
It's a spring and plate type
