Nitrous on my 98 Trans am
Old 03-23-2013, 03:47 PM
Joes98Blackbird's Avatar
Default Nitrous on my 98 Trans am
I have a question? I have a cam, stall, full exhaust and a 85mmTB/LS6 intake on a 1998 Trans am and I was wondering about trying nitrous. I am going to have the computer swap to a 2001 and tune at EFI in Jacksonville FL. this coming spring, but I've heard that you will have to run bigger injectors for just a 100 shot. Is this really true for just the juice that I want. I have a Walbro Pump and i'm Installing fuel rails on the car next week before I take it up there for the tune. I wanna hear what yall guys have to say on this..... Stock injectors or 03/04 cobra injectors as an upgrade to handle the nitrous...? Thank you very much?
Old 03-23-2013, 05:04 PM
HCI2000SS's Avatar
I would definitely do it! Personally i'd go with some 42's, so it will give you a little room to grow as well
Old 03-23-2013, 09:21 PM
krissoto's Avatar
Only reason you would need a larger injector is if you go dry.
Old 03-23-2013, 09:55 PM
egod's Avatar
like Krissoto said the injectors aren't maxed out. Usually its the full pump that needs the upgrade first and it sounds like you have that covered. Best of luck.
Quick Reply: Nitrous on my 98 Trans am
