2 issues: Lterms frozen at 0.0 and -3.1 cruising and running WAY hot.
Just got it back because had a bad overheat and had the Heads decked. Was told Electric motor in Meziere was bad so it was fixed.
I don't know if this is an electrical issue or TPS or O2 but not throwing codes.
Lterms freeze cruising and only change when I stop and idle.
Running fine other than being hot; up to 235* cruising at 2400 rpm's with AC on max and high.
When I stop the temp drops 10* before the light turns green and I cruise again; then temps go back up to +230*.
Gonna change TPS and swap Tstat to be safe but can a bad TPS make the car run hot?
Why would the Fuel Trims freeze and then work "kinda" normal at a stop/idle?
