How do you by pass the neutral safety switch on a auto
Moderator
Without the neutral safety switch you could start the car in gear and be in an accident or drive over your child before you could react. Its very dangerous; that's why it is not in the stickies.
Moderator
NHRA regulations require all cars to have a neutral safety swithc:
https://ls1tech.com/forums/drag-raci...rness-etc.html
http://www.nhra.com/UserFiles/file/U...0Unleashed.pdf
I used the wires from the clutch switch and wired them to wires on the tranny harness for the neutral safety switch. This is a C5 so I'm sure the wire colors are different from an F body tho..
