possible procharger leak?
So I found some oil collected on the bottom of my D1SC. I'm not sure where it is coming from. I have a small air/oil seperator in line with my pcv system. It had only a very little oil in it. It mostly had water collected in the bottom of it. So it wouldnt seem like the oil is coming from the PCV system. I then began un screwing the oil fill on the procharger and as I was loosening the screw, air began seeping out. So I continued to loosen the screw and pressure continued to release. Is this normal for the procharger to be pressurized? Now that I have wiped off the bottom of the procharger I havent found the source of a leak. This procharger is brand new, I have about 300 miles on it. The motor is freshly rebuilt with a procharger in mind and has the same mileage. Any ideas? At first I thought maybe the drain just isnt tight enough, but Iwouldnt think tha tnow that I know it was holding that pressure. There was also a small amount of oil in one of the coupling's after the procharger.
LS1Tech Sponsor
The head units to get pressurized, and a little oil will seep out of the fill plug/dipstick. The oil is so thin it often does not leave a trace until it drops off the bottom of the blower. I've had customer's swear the oil was coming from somewhere other than the fill, and that is where it ends up coming from. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Ok so if it is coming out of the fill there is nothing to do? I should expect to see some oil under normal circumstances? Is it going to blow some of it into the plumbing as well?
LS1Tech Sponsor
You can replace the white seal under the plug, a new one is on the box of the the extra case of oil. This might seal it up. It shouldn't blow into the plumbing. Bob
__________________
I'll check the seal. so if oil is in the plumbing it would only come from the pcv? how long should it take for the rings to seat on my freshly rebuilt motor? could this temporarily allow some additional blow by?
LS1Tech Sponsor
Yes, the oil should only be coming from the pcv. Rings on a well built engine should seat almost immediately. At the old shop we use to build engines and install them in the customers cars, fire them up and check all fluids,etc. We would then get them on the dyno and do all the part throttle tuning. We would then change the engine oil. After that we did the wide open throttle tuning. When the vehicles came off the dyno the engines were pretty well broken in. You might have a problem if your engine isn't properly ventilated. How do you have the pcv hooked up? Bob
__________________
