17" zr1s...what tire to make a 28" tall
Right now Im running 275/40/17 M/T et streets on factory zr1s. I have 4.11s and this set up I believe it 26.5" tall. Im trapping like 100rpm before redline. Stock long block car. I plan on spraying the car but I really do not want to need 5th gear before the traps. Will a 28" tall tire allow me to trap 120+ in 4th gear? Im trapping 114 now and I believe Ill be on the limiter at 115. Can I run a 28" tire on a 17x9 wheel? If so what size
I just bought the 325 45 R17 direct from mandhtires.com 299.00 each. I believe they are the only ones making a 28" DR for a 17" rim. They hook like you wouldn't believe. By far the best DR that I have used.
