Carb back to EFI
Carb back to EFI
I have a carburator set up right now and want to convert back to efi. What all do I need to do this? I have nothing efi related, so I know I need a harness, knock sensors, ecu, injectors, intake manifold, and throttle body, anything else? What is the cheapest way to get this stuff and what can I get to tune myself easily that doesn't require dyno tuning. As a reference point I'm running a mostly stock Ls1 with an ms4 cam kit. Thanks in advance for the help
Had it on my lq4 with cam. I could never figure out how to dial in the timing and the efi and ez efi would get in fights and then motor would die. It had great power and all. If you are good with timing tuning it may work out. It is also very expensive. You can get a harness and ecm for around 700 bucks. so that leaves 1300 for intake and fuel system. I just did the exact same swap. I had carb then ez-efi and now just did my first drive with factory efi.
With that size cam Id assume you might want to go with an aftermarket intake, tb, injectors etc. If not I have a lq4 truck intake (good for torque but tall in size), along with injectors, fuel rails,throttle body, MAF etc id be willing to sell or maybe trade you. im looking to go carb on my lq4 and need a intake and MSD 6010. If interested in working something out potentially or if you want to sell your stuff shoot me a PM
