Stained/pitted chrome
How do I fix this? it's from sitting over the winter. Not sure what caused it. I don't have money for new wheels and I don't have a garage for the car either.
I cleaned the wheels with some A2Z Wheel&Tire cleaner but it didn't do anything. Buddy said to try some distilled vinegar.
Nope...stick with the chrome polish. I'd be surprised if the Mothers ball would do much. Might help but you're follow up with a by hand effort anyway soooo....
If that's what it looks like in the pictures, it's the early stages of rust. If that's the case starting looking to replace them, rechrome them, or powdercoat.
If it's just staining, try a course kitchen sponge and some CLR (calcium lime rust remover) for bathrooms and wax afterwards.
Chrome isn't something you can really "polish" like aluminum so much as just clean it and wax it for protection.
Look for "Wadding polish." Should take care of most of that ****, simply just rub on the wadding polish and then wipe it off a few seconds later.
http://www.eagleone.com/nevr-dull-wadding-polish
I have a can of that in the garage. I've yet to find anything it works well on honestly.
Doubt it will remove much damage but it should leave enough wax to help protect. It generally leaves a hazy waxy finish on whatever I've used it on which is part of why I don't like it.
Unless I can trade someone for a set of C5 ZO6 wheels..
But this is what I did:
CLR w a "Magic Eraser" (Still don't like these)
Chrome polish
Coat of Wax to help protect it.
Looks a LOT better!! Probably cleared up about 65% of it. Still should be either powder-coated or re-chromed to keep the moisture from getting under the chrome. Needs to be sealed. Not worth it for me. I put these in the classifieds for trade. Wish I could get some DD ZO6's. Can't find them wider than 9.5's.
I'll post pics in a bit.
Pontiacerator
You got a very good result! Just polish them from time to time and they'll continue to look good without significant deterioration. I wouldn't get rid of them if I were you (but I'm not).
I've used Simichrome polish for years - a German product and it really works wonders. Surface rust is not a problem.
