AFR/ FAST/Comp/Circle D/ Madman and more!!!
. All prices are plus shipping and 3% paypal fees. LOCATED IN SOUTH MISSISSIPPI .Here we go:
ALL PARTS WERE GOING TO BE USED ON AN F BODY
1. 6.0L 2001 lq4 block (used), stock bore, checked and vatted by machine shop, with front and rear covers $400
2. ARP Head studs 234-4316 (new) Partial set (8 long, 2 medium, 10 short, nuts and washers) got scammed a while back 75$
3. LS6 Valley cover (NIB) $100
4. Comp double roller Timing gear set 7106 (NIB) $100
5. Scorpion LS1 Roller rockers (used) 1.7 ratio. a couple have rub marks on the bottom where they were installed incorrectly and I rolled the motor over. its only cosmetic and will affect nothing. $175
6. Low profile S/S valley cover bolts for use with FAST intake (NIB) $10
7. 2 sets of Center bolt Valve covers. 2 pair natural $40/set,
ALL PRICES ARE OBO
HEADS, Cam, Intake
8. AFR 230 v2 (dyno time only) milled to 65cc, 2.08 100.8gram lightweight intake valves/1.60 97.3 gram lightweight exhaust valves($400+ upgrade) AFR dual valve springs
158 lbs @ 1.790", 447 lbs @ 1.160 , coil bind 1.110". Clearanced for 3/8" pushrods, cleaned and reassembled. Heads and Intake port matched. I bought these heads with dyno time only on them and the previous owner had a detination issue. 3 valves were pitted. I had the 3 valves replaced and had an anti detination port done to them. ALL WORK DONE BY BRIAN TOOLEY of Brian Tooley Racing. Heads have not been run since being gone through. I have over 3500 in these heads. $ 2650
9. Comp Custom hydraulic Roller Cam 251/259 .62x/.62x 113+4 Brian Tooley Spec'd this cam for the 13.5:1 408 I was going to build (NIB) $300
10. FAST 102 mm Cathedral port intake. Ported by Brian Tooley for the AFR heads above. I was shaving the shell of the intake down to paint it, and was about half way done when I decided to sell everything.
Has not been run since ported .$725
11. Circle D TH350 level III 4.5 C converter . Stalled 4800 on my 540 rwhp ls7 (used) $550 (sold )
12. Madman Manual steering rack . Needs metal plate to mount to rack and weld to k member. (used) $ 300
13. SSRA Megamouth ram air intake non a/c verson (NIB) $110
14. stock 6.0 L crank. machine shop says it needs to be blasted and polished. $75
ALL PRICES ARE OBO
GM GASKETS
15. Timing chain cover gasket 12633904 (NIB) $10 (sold)
16. Rear cover gasket 12639249 (NIB) $10
ALL PRICES ARE OBO
HEADS, Cam, Intake
ALL PRICES ARE OBO
GM GASKETS
