99 z28 no start
Old 03-24-2013, 06:20 PM
bpt071's Avatar
Default 99 z28 no start
hey guys, didnt know exactly where to put this so if its in the wrong place please let me know. kind of at a stand still on an issue that occured friday, friday morning my car started up with no issues ran fine and everything. parked it for about 8 hours and when i went to start if up my starter clicked once, guages and everything went dead etc. got it back home to start working on it. tested battery (12.55 volts), as well as the same voltage at the starter. fuses good, relays working. grounds seem to be fine. put it on a battery charger just to make sure battery was good and it was all fine. any other ideas or possibly something i could be overlooking? any help would be appreciated.
Old 03-26-2013, 10:34 PM
wild1100's Avatar
Check ground from battery to frame. Did you test battery with a load.
Quick Reply: 99 z28 no start
