General LSX Automobile Discussion Non-technical LSX related topics.
How much you paid your builder?
Old 03-25-2013, 02:54 AM
Jadedbird's Avatar
Default How much you paid your builder?
How much did you pay for you builder to go thru your motor? Install a heads/cam kit? Check clean pistons? Etc?
If you dont mind me asking.
Old 03-25-2013, 03:10 AM
Burken01's Avatar
If the engine is out of the car, I would guess at 2k for that at a decent sized shop...
if engine was in the car, add 1k for that..
and I'm talking labor, not parts
Old 03-25-2013, 03:14 AM
camaroz98's Avatar
do all my own but spend anywhere from 300-800 at machine shop for cleaning, bore, balance depends on state and locations they have also always seated my valves and installed cam bearings. charge my friends unlimited beer and 200 bucks to put there motors together tho.
Old 03-25-2013, 03:20 AM
Burken01's Avatar
do you put the shortblock together or just the heads and intake and cam together...
I would have a machine shop do the shortblock, you need all the clearances checked and everything has to be perfect... piston to wall clearance depending on piston material and that all changes if your NA or FI and power levels...
a good machine shop will charge 500-800 to do a good shortblock that will last for big power and be reliable.
Old 03-25-2013, 03:24 AM
camaroz98's Avatar
i put it all in i just have the shop acid dip heads, block and bore block and deck both plus balance it but they always seat my new valves, freeze plugs i paid 300 for my talon and 500 from a friends camaro in vegas but for my lq9 here in cali was 750
Old 03-25-2013, 03:26 AM
Burken01's Avatar
what do they balance?
camaroz98's Avatar
well 750 in cali with no balance but they did check the old crank and cam for bends since most my build i use new cams and forged crank
Old 03-25-2013, 03:28 AM
camaroz98's Avatar
crank with pistons and rods and bearings so the bearings are all checked and installed normally ive only done 5 full motors tho
Old 03-25-2013, 03:29 AM
Burken01's Avatar
which forged cranks are you using on your builds?
Old 03-25-2013, 03:31 AM
Burken01's Avatar
you dont have to balance a stock rotating assembly even when changing bearings... it shouldnt change anything, but you mentioned you always do forged cranks with your builds so yeah it would need to be rebalanced
Old 03-25-2013, 03:33 AM
camaroz98's Avatar
i used eagle w eagle rods and wiesco pistons on my 3 DSM builds they all were with in .001 gram when finished, havn't used one on a lsx build looking at them right now trying to figure out if i want to rebuild my ls1 or trade block for block with my friend with his LQ9 bored 30 over already
Old 03-25-2013, 03:36 AM
Burken01's Avatar
stock ls1 cranks can handle 1,000 HP so unless your supercharging your car, which puts more stress on the crank... I would stay stock..
But if you have the cash and want forged then it would work too
camaroz98's Avatar
reason why im stuck with my camaro build i want a 408ci stoker but everyone up here chargers up the butt for a balance which ill need or take it to vegas.
Old 03-25-2013, 03:39 AM
Burken01's Avatar
my shop charges $200 for balance of the rotating assembly
Old 03-25-2013, 03:41 AM
camaroz98's Avatar
who do you go with might be worth the drive i was told 400 up here for the lq9
Old 03-25-2013, 03:45 AM
Burken01's Avatar
where are you at in cali
Old 03-25-2013, 03:52 AM
camaroz98's Avatar
edwards afb its up by palmdale the high desert bout 2 hrs north of you but i have to go down to l.a. and long beach alot for my GF's family
Old 03-25-2013, 03:56 AM
Burken01's Avatar
Oh, my shop is in Escondido. Another 1 1/2 hrs from where I'm at... With gas that would not be worth it
Old 03-25-2013, 03:58 AM
camaroz98's Avatar
well i have a co-worker who goes down to SD every other weekend so i might be able to load it up with him and have him drop it off
Old 03-25-2013, 04:00 AM
camaroz98's Avatar
sorry to over run your thread but as you can see the price goes a lot off of what you want done and where you are at for prices
Quick Reply: How much you paid your builder?
