98 ls1 into 02
98 ls1 into 02
putting engine,harness,computer,from my 98 camaro into a 02 camaro.just relized the 98 has the 3 wire plug and the 02 has 2 plugs.I see that i might have to repin it.do they make a conversion kit,or can i pull the 3wire set up out of the 98.will it still run if i just plug the 2 in for now.just some of the guages wont work?.any help would be apprecated.thanx howie
P:S told my son to check all of this before we started it.another fine mess he got me into.
LS1Tech Sponsor
Yes you can use it. The 'C' position is for the gauge cluster.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
?.. if so.. I would just use the 98 LS1 as a long block with accessories, intake, etc and then find a 99+ wiring harness, sensor, and PCM.. to match your year F-Body. would swap in a lot easier.. You mingth have to extend some part of the harness (Notch Sensor ?). Otherwise, it would be a easy swap.
Also, tuning is a lot better on the 99+ (411) PCM's over the 97-98 ones.
BC
BC
