Any reason not to do an alternation relocation?
Old 03-25-2013, 11:22 PM
Xovit's Avatar
Default Any reason not to do an alternation relocation?
I own a 2002 Z28 Camaro with roughly 86k on it. I have a few maintenance things coming up and in the process I’m planning to upgrade. These upgrades include a step up to a 200amp alternator, battery, starter, power and ground cables, belts (since they are squealing), SLP Harmonic balancer..
Now, in this process I was also going to replace the belt tensioners despite them likely being good, but in that research I came across this relocation bracket: http://www.cbrperformanceproducts.co...tCode=06072011 Instead of upgrading the tensioner would there be any reason not to go with this setup since I’m replacing several things(outside of this being a turbo option)? Is there any downside to eliminating belt tensioners? I still run my AC which I’m aware is on its own belt. Any/all input is appreciated! I did try and search and didn’t find detailed info on what I’m looking for… thanks!
Old 03-25-2013, 11:25 PM
djfury05's Avatar
The alternator looks like poop up on top of the motor like that. Leave it where it is and get the tensioner.
Old 03-25-2013, 11:28 PM
Xovit's Avatar
Outside of looks though, nothing mechanically bad?
Old 03-26-2013, 12:02 AM
djfury05's Avatar
No.. might be harder to get the belt on that's it.
Old 03-26-2013, 12:43 PM
dailydriver's Avatar
The only real advantage to that location which I can see is that it keeps the alternator out of deep water on a daily driver (which is about a half of a percent of the owners on here) driven in areas prone to flooding.
That, and it's easier to change if it does puke out.
Old 05-01-2013, 02:39 AM
LT1559's Avatar
I hit a big puddle and it surged my battery. When I got out I could hear the battery boiling. I'd definetely consider relocating it.
Old 05-05-2013, 09:40 AM
cookba's Avatar
the main reason to doing the alt relocation is because the 4th gen's have the power steering pump right above the alternator and they have been known to leak/boil over ps fluid down onto the alternator, frying them prematurely. Not to mention they are a PITA to get to when you have a large front swaybar. I would want my alternator up top and probably will one day, plus it will save you some wire when you do the BIG 3.
Old 05-05-2013, 02:14 PM
maxpower_454's Avatar
The real question - Is there any reason TO do an alternator relocation? PS leaking and water are ridiculous reasons for crapping up your engine bay. Save your money....
Quick Reply: Any reason not to do an alternation relocation?
