Where are you guys getting your intake tubes/hoses?
Old 03-26-2013, 07:54 AM
Ksths2's Avatar
Default Where are you guys getting your intake tubes/hoses?
Subject pretty much sums it up
I'm needing a 4" ID silicone or rubber 90 degree hose from the TB and a straight piece of 4" of either aluminum or plastic or whatever you guys are using with a 4" coupler
thanks!
Old 03-26-2013, 08:02 AM
ctd450's Avatar
I use intakehoses.com.
Old 03-26-2013, 08:26 AM
E.rodz's Avatar
Silacone intakes.com great sorce for this.
Old 03-26-2013, 09:06 AM
bczee's Avatar
I get my rubber elbows and Aluminum Tubing from Jags that run (JTR).
But like the others stated Intakes.com and many others places, try a search. This has been asked before and many sites have been listed before.
BC
Old 03-26-2013, 09:49 AM
Ksths2's Avatar
sounds good, thanks!
Old 03-26-2013, 09:29 PM
Docked Wage's Avatar
For aluminum tubing or at least something that looks like aluminum try using aluminized steel exhaust elbows for heavy truck applications. I hit this one with a buffing wheel and no one knows the difference until I tell them.
For the Rubber Elbows I use SiliconeIntakes.com
Good luck,
Ken Wolkens
Attached Thumbnails Where are you guys getting your intake tubes/hoses?-jeep-5.3.jpg
Old 03-26-2013, 10:54 PM
Blackpony's Avatar
i typically get my stuff from summit. the cai on my truck right now is 3.5 inch i have about $60 invested in it. Its polished aluminum with black couplers
Old 03-27-2013, 10:11 AM
LsoneGT's Avatar
I made mine out of PVC from home depot. Cost 10$ and works fine
Old 03-27-2013, 10:34 AM
JOHNBOY66's Avatar
Racepartsolutions is where I get mine along with many other things.
Old 03-28-2013, 02:04 AM
01cherryreds10's Avatar
Couplers and clamps from intakehoses.com, plastic tubing is from Airaid. It's very easy to cut and comes in a huge U shape. You could build two or three kits out of one big bend. One day I'll have time to smooth it with sandpaper and paint it gloss black
Attached Thumbnails Where are you guys getting your intake tubes/hoses?-306219_10150711225023577_681318576_9414498_720896154_n.jpg
Quick Reply: Where are you guys getting your intake tubes/hoses?
