2001 Camaro Z28 project, lightweight, single plane
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $10000
Mileage: 88000
Private or Dealer Listing: Private Listing
Location (State): KS
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
-stock short block stock heads
-custom patg cam
-Vic jr
-accufab 4150 throttle body
-quick time performance headers
-aeromotive fuel rails
-speed inc 42lb injectors
-prc 650 lift springs
-k&n air cleaner
-aluminum throttle cable bracket
-th350 with transgo stage 3 shift kit
-ptc 8" converter stalled to 3800
-b&m ratcheting shifter
-grant aluminum steering wheel
-strange sa with 275lb hypercoils
-mwc k member with solid motor mounts
-mwc manual master cylinder
-biondo line lock
-vfn wide Sunoco extended hood
-comp engineering 3 ways in rear
-spohn tunnel mounted torque arm
-bmr crossmember
-lca relocates welded in
-Lakewood lca
-umi adjustable phr
I think that's it, or most of it. I've put quite a bit of work into this car. All hvac is gone and a lot of wiring has been redone. I redid all the hard brake lines in the car as well. I've cut the cowl back as well. Car will be on 16" snowflakes. If anyone is interested I strongly encourage them to call me. I will respond here and in text as well but it's easier to give the full rundown through a phone call.
Asking 10,000 or best offer. Not really interested in trades. Maybe if it's a cheap fox with cash on top.
Call, text, respond here or email. 913-240-4729 Zach.burge@yahoo.com
