mt et streets and dragbags psi
I am taking my car to the 1/4 mile track this friday after about a year since the last time I went. I just need to know what psi do you guys normally set your dragbags and mt et streets too since I forgot what I used to set them to . Thanks
05 gto. Full bolt on, 150 shot, cam a4 3400 stall
those tires are very sticky, so you probably won't need to at the track, but you can safely drop drag radials down to about 12 psi, just air them back up before you head home. I know several people who will drop them to the single digits without issues, but i wouldn't.
I tought it was too much sidewall to lower the psi too low. I can't ever really get this tires too hook right.
The increased diameter is effectively changing my 4.1:1 diff gears back to about 3.7:1 which may be a big part of the reason that it a lot less violent off the line, yet is still running 1.5xx sixty foot times.
A side benefit is that that take a lot less time and speed in the burnouts to heat up.
