FAST 102 LSXrt manifold height?
Old 03-26-2013, 11:51 PM
65442's Avatar
Default FAST 102 LSXrt manifold height?
I have been looking around to find out how much taller the FAST truck manifold is, compared to the stock and FAST car manifolds. Can someone help me out?
Thanks!
Old 03-27-2013, 01:15 AM
Hamrdown's Avatar
They're around 10 1/2" tall. Too tall for an f-body unless you cut the cowl and remove the wiper motor above it combined with spacers to drop the K member slightly.
Old 03-27-2013, 10:27 AM
65442's Avatar
Right. But I don't have an F-body. I just want to know how much taller the intake is, compared to a stock LS6 and/or FAST intake. Thanks
Old 03-27-2013, 02:54 PM
Blackpanther99's Avatar
Couldnt find a clear answer, but I believe its a 3" difference.
Old 03-27-2013, 06:38 PM
65442's Avatar
I called FAST and they said it is probably 4-4.5" taller than a stock-height manifold. Didn't have any schematics to reference. So I guess that's as close an approximation as I'll get.
Old 03-28-2013, 01:51 PM
Super Hulk Smash
JakeFusion's Avatar
That's sad isn't it. They don't even know the dimensions of their own products. But that was my guess in the other thread. Woo.
Old 03-28-2013, 02:52 PM
Sponsor
Speed Engineering's Avatar
We have a regular LSX 102mm intake we can measure here, but not a truck. Here is a pic of the two next to each other hope it help some:
Thanks
Sean
Old 03-28-2013, 07:17 PM
65442's Avatar
Yeah, Jake. I was surprised. You'd think that knowing the difference in height between LS6, 102, and 102 truck manifolds would be very relevant information to them and their customers.
Sean, could you please measure for me? Is the 102 any taller than an LS6 manifold? How will you be measuring? Assuming that the manifold rests on the lowest part of the flanges, then just setting each manifold on a table (like in the picture) and measuring the height from table surface to top of manifold should do the job. Maybe I can talk some guy at FAST into doing the same with the truck manifold.
Old 03-29-2013, 01:16 PM
Sponsor
Measuring on a flat table. The LS6 intake measures approx 6" tall, and the 102mm measures approx 7.25.
Thanks
Sean
Old 03-29-2013, 04:28 PM
Thanks for that info Sean. Did alot of info searching but couldnt find a clear answer. Pretty sad FAST doesnt have their products dimensions measured out.
Old 03-29-2013, 09:22 PM
65442's Avatar
Thanks, Sean! I assume that the undersides of the intakes (the places where the intakes made contact with the table) would not account for any of the difference in height?
Now I just need someone to measure an LSXrt manifold! Anyone?
Old 04-21-2018, 03:21 PM
Seabee's Avatar
Default Novice
The LSXRT height is 10 and 3/4 inches tall when measuring it from a flat table surface to the top of the intake manifold. Hope that helps.
Old 04-21-2018, 08:16 PM
Fishmasterdan's Avatar
And if measure off the valley cover. It touches the valley cover.
Old 04-21-2018, 11:12 PM
wannafbody's Avatar
Here's something to think about...according to the Hot Rod 20 intake shootout, the 102 and the truck intake were within 1 or 2 hp of each other. In other words, there isn't really any advantage to the taller truck intake.
Old 04-24-2018, 08:58 AM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Regarding the LSXRT manifold, the upward angle of its snout pitches the throttle body up at an angle. This can also cause clearance issues with the hood. The air intake tube that attaches to the TB can be tricky to get situated because of the upward angle of the TB.
For my 91 RS Camaro the LSXRT fit under the hood and the TB cleared but the air intake tune didn't. This required a custom metal air tube with the very top shaved flat and a plate welded to it.
LSXRT on my 3rd gen Camaro
The shaved air tube is visible in the above picture. The one below may offer a better view.
The driveability Of the LSXRT was terrible on my small cam 383 LS1 stroker. In actual dyno testing the LSXRT proved to be consistently 2hp worse than a modified 90mm snout ported LS6 intake on my small cam 383 LS1. Big cam the LSXRT would have done better the Fast LSX was within 1 hp of the LSXRT on my engine.
The air flow experts I've talked too say that sort of outcome sometimes occurs - and none of the were surprised.
​​​​​Had I known then what I know now the LSXR would have been a wiser intake manifold choice for my car. It would have fit without the custom air tube. The tuning would have been more straight forward.
On the other had I did end up with a nearly new LSXRT intake manifold sitting on the shelf collecting dust. I've used it in my intake manifold flow testing. The LSXRT does flow very well but for real sucess with this manifold I think 400+ cubes engines and a big solid roller cam plus too notch cylinder heads designed for that sort of application are a good idea.
​​​​​​Best wishes for your project and sucess.
Quick Reply: FAST 102 LSXrt manifold height?
