High Idle
High Idle
I searched and couldn't find what I was looking for..so...My car idles high all the time. If I perform the idle "relearn" procedure, the car will idle where it should. As soon as I turn the car off and let it sit, I start it back up, the idle is high again...any ideas..Thanks for any help!
Could be a dirty or faulty Idle Air Control valve. My '00 Z28 was doing the same thing as your's and I was instructed to just take some carb cleaner and clean mine. It worked for about a day and returned to high idle. I bought and replaced the valve (10 minute job from start to finish) and it was perfect after that and still is. This was probably over a year ago that this happened with mine;
IAC Valve
IAC Valve
