help! tpi tps on lt1??
i just bought a lingenfelter 58 mm throttle body and little did i know it was on a tpi before and i cant take my lt1 tps and swap them over.so my question is can i buy the tpi tps pigtail and cut mine and plug it in? the colors apear to be the same.and what about the voltage and ecu signal? anyone help?
I got out of work at 3am and was half asleep when I posted........
I have a 58mm aftermarket TB that came off a 93 car and had a different IAC and I just posted the solution I used for that when I saw a question about an earlier TB on the later motor. maybe I should have slept before posting.
