What I've done so far
So I have some updates on the Camaro if you're interested, some videos and pictures.
Heres the exhaust video
Background on the car, bought this last year completely stock minus a strut tower brace and subframe connectors.
I recently installed the SLP Lid, smooth bellow, rerouted the coolant line to the TB, removed the MAF screen, and lightly ported my TB.
I added a Fuel pressure gauge and wideband gauge in as well
then i installed my TSP 1-7/8" LTs and TSP 3" dual exhaust. (i bought some 42lb injectors for when i get down to Ft. Worth and get a trickflow heads kit)
relocated the battery, then adding a system because the stock one was horrible. I added the 160 amp truck alternator because the stock one was failing and i needed the juice. here are some of those pictures.
fans were added because the amp under this one was causing too much heat.
shortened the shifter until i get a MGW
and finally the final product so far
Let me know what you think so far!
Thanks! I'm glad you like it. and the exhaust has definitely hit the ground already. i was going to lower it with some stranos but now... not so much. maybe if i got some 18's in the rear haha
as far as i know its still stock. it does have bilstein shocks. from what ive heard not all camaros came with that. it was a little lower in the rear because the battery, sub, amps and muffler but it leveled out pretty well after i took the exhaust out.
