12:1 CR... What starter?
Just got my 370 build complete.. I took started it several times and put roughly 50 miles on the car since completed.
I did a few small things, installed nitrous, hid some wires, etc... Went to load the car up on the trailer for a tune... No go.
The starter gear shoots out like it is going to start but doesn't turn the motor over.
We took the starter off and put it straight power/ground and it shot out and spun. I don't think this means that the starter is good though??? If it does, it would make me think it was a bad ground/etc somewhere... However, only one ground was removed and I have double checked it, it is good. The battery is also good and was swapped for another one.
What are you high compression guys running for a starter?
The starter that went out (I think) is a CVR? high torque starter. Hasn't been on the car all that long. Have NEVER had an issue out of the starter before this.
Thanks
Thanks
Ended up buying a reman lifetime starter... IIRC it was a 2003 6.0 truck starter. Nice looking starter, it has the two long bolts as well.
It was 14X-150X$.
Started up the first key turn and sounds better than the other one.
Thanks for the input guys.
It was 14X-150X$.
