Coil Relocation
Coil Relocation
Where are you guys relocating your coils to? I picked up some nice looking valve covers and don't want to hide them under the damn coils, so was thinking about moving them. Let me know where you moved them and how much a PITA it was. Are you extending or moving the coil harnesses? Post pics if you have them. Thanks!
I put mine under the cowl. I am using truck coils and bought the brackets from CBM Motorsports (http://www.cbmmotorsports.com/index.html) off of eBay (http://www.ebay.com/itm/CBM-11016-GM-Truck-Gen-III-coil-relocation-bracket-Vortec-4-8-5-3-Ignition-D581-/220986608662?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3373d40c16) Then I bought a harness extension from Current Performance Wiring (http://currentperformance.com/index.html) and had them put the spriral sleeve on it. Everything looks tight and professional, not junky and crowded!
Chad
Chad
I put mine under the cowl. I am using truck coils and bought the brackets from CBM Motorsports (http://www.cbmmotorsports.com/index.html) off of eBay (CBM 11016 GM Truck Gen III Coil Relocation Bracket Vortec 4 8 5 3 Ignition D581 | eBay) Then I bought a harness extension from Current Performance Wiring (http://currentperformance.com/index.html) and had them put the spriral sleeve on it. Everything looks tight and professional, not junky and crowded!
Chad
Chad
BTW thanks for the wiring link!!!
1 Post
I've heard of some being placed behind the heads in between the firewall, but on my car, it isn't an option without mangling the firewall. I've heard of some being placed in the wheel wells up high with protective covering. I've seen some placed on what would normally being called the frame horns up front but down low.
Also be sure to mark which coil goes to which cylinder before you start, and which harness plug goes which bank.
That will just make it easier on you when you go to put your plug wires back on.
