Holley lsx oil pan?
I've got one on my 69 Camaro. The fit and finish was great, and there's loads of clearance at the steering linkage. The pan doesn't come with a windage tray- the small, square piece you're seeing in the pics goes down in the sump to keep oil from sloshing away from the pickup. You use your stock windage tray.
I bought the BRP kit very early on and sold my 4th gen pan because I did not want a welded pan and they did not have one of these at the time. I am going to pull my motor to put one in just for the clearance when I get a chance. Note on the pan you should have a full windage tray not the one that comes with the Camaro those do not cover the entire bottom of the motor.
The F-body pan used a 3/4 tray because the front of the pan is not as deep (maybe by 1/2 - 3/4 inch.) As many or most of the other pan's. Take a look at some pictures of the F-body pan as compared to others. Would allow the engine to sit lower to the cross member.
If you only have 3/4 of the lower end/rotating covered, you would lose 25% of the effect of the windage tray and what it is designed to do. Most likely you would not even feel anything unless you were turning 7 or 8000+ rpm's. If at all.
For most, IMO, it wouldn't make any different. Just nice to have.
BC
BC
