How to prevent meth spraying on 2-step?
Old 03-30-2013, 11:43 AM
35thsscamaro02's Avatar
Default How to prevent meth spraying on 2-step?
M6 d1sc with meth on hobbs switch. Im worried that if I set a two-step at Let's say 5000rpm it will be spraying meth while on the two-step. What's my solution? Is there a way to cut power to meth pump when clutch pedal is pressed? Thanks for any input.
Old 03-30-2013, 01:55 PM
25thhawk's Avatar
not sure what 2-step you are using, but I have a harlan 2 step from years ago that has an ouput wire so that you can wire up a nitrous system to come on as soon as the 2-step input is released
Old 03-30-2013, 02:27 PM
LS1Tech Sponsor
Slowhawk's Avatar
If it's an alky control setup it has a wire to hook up to stop spraying on the 2-step.
Old 03-30-2013, 03:01 PM
It's a msd two step and AIS meth kit
Old 03-30-2013, 03:20 PM
3pedals's Avatar
what is wrong with spraying water/meth while on the 2 step? not smart ***, seriously want to know, as my setup will do this when it hits the track for the first time
Old 03-30-2013, 04:49 PM
Sales@Tick's Avatar
Rich AFR might cause it to be sluggish off the line. I'm sure you can find ways around it being sluggish off the line, but I would think wiring an interrupt relay would be best for the methanol pump.
Nitrous guys use an interuppt relay to interrupt their nitrous solenoid relay so it doesn't spray on the trans brake.
Old 03-30-2013, 04:50 PM
3pedals's Avatar
thank you
Old 03-30-2013, 05:02 PM
Blackpanther99's Avatar
Thats interesting, I always heard about people wanting to cut off their meth while the 2 step is activated. Never really knew the reason behind it.
Old 03-30-2013, 05:04 PM
Sales@Tick's Avatar
I'm sure you could find a way to pull fuel to keep the AFR optimum in the tune via the VE table or other secondary tables that pull fueling, but I would think just turning the methanol pump off would be easiest to not complicate tuning.
Old 03-30-2013, 05:17 PM
Not to thread jack the OP, but is it running meth while the 2 step is activated always a bad issue? Even though lets say there isnt soo much meth being pumped in?
Old 03-30-2013, 05:27 PM
Sales@Tick's Avatar
If the AFR was optimal with the methanol spraying I see nothing wrong with it spraying. I used to spray methanol on the two step on my old car with no issues, but I did foul out all my plugs and o2 sensors once from setting the activation too low and the AFR got too rich.
Old 03-30-2013, 05:28 PM
coolmanvette75's Avatar
I ran a relay that killed power to my nitrous solenoids while the 2step button was pushed in. I'm sure something similar can be wired up for meth...
Old 03-30-2013, 05:41 PM
Ouch, I see, will definately cause some slowing down off the line. Thanks for the info Martin. I learned something new today.
Old 03-30-2013, 08:35 PM
Yea I just figured meth spraying while on two step would be bad. So anyone have link to controller that could solve my concern?
Old 03-30-2013, 08:40 PM
Or will a big fire ball be my only concern ??
Old 03-31-2013, 07:42 AM
I think its just done by wiring the 2step to the meth pump, soo whenever you activate the 2 step the pump will cut off and when the 2 step button is released the pump starts pumping meth again.
Old 03-31-2013, 11:06 AM
Yep that's what needs to happen I just am unsure how to do it. Anyone wire up a two step and meth pump this way?
Old 03-31-2013, 11:17 AM
fotoboy's Avatar
I have a relay kit that would prob work. I had it for my n20 bbc car so I could tbrake off the line at WOT wo the spray comming on until launch.
Old 03-31-2013, 10:15 PM
Sales@Tick's Avatar
Look up how to wire a nitrous interuppt. Replace the nitrous relay solenoid with your meth pump relay and your done.
Old 04-01-2013, 01:22 PM
anyone want to walk me threw this? I think I understand this but I wouldnt mind someone holding my hand lol Im a plumber not really into "wiring"
Quick Reply: How to prevent meth spraying on 2-step?
