Can I use a stock balancer with an ATI hub?
Old 03-31-2013, 09:27 AM
FlatBlackZ28's Avatar
Default Can I use a stock balancer with an ATI hub?
Will a stock balancer mount to an ATI hub without any problems? I needed a replacement hub, so I purchased the ATI unit, knowing that I would also eventually be purchasing an ATI super damper. For now I had planned to just run the stock balancer. When I went to bolt it on, the center ring on the new hub is much larger than the hole on the existing hub, but the bolt pattern still matches up. There is just a gap of about a half inch.
Is anyone else running a stock balancer with an ATI hub?
Help please!
Old 03-31-2013, 11:28 AM
fex77k's Avatar
NO.
The press fit and the bolt pattern on mine are nowhere close to stock.
Old 03-31-2013, 12:31 PM
Moderator
BizZzatch350's Avatar
Old 03-31-2013, 03:26 PM
leadfoot4's Avatar
If all you need is the hub, get a Powerbond piece. I have one, IIRC I bought it from Golen Engine Service....
Old 03-31-2013, 04:11 PM
BOLO's Avatar
Do you need a stock 94-95 hub for your balancer? If you do, I have both. Lmk.
Old 03-31-2013, 05:00 PM
Moderator
I got one for my C6, nice piece.
Old 04-01-2013, 07:12 AM
Well, I already spent $154 on a nice ATI hub (because summit didn't have a stock replacement instock at the time, and the stock replacement hub was almost $100 anyway) and had a custom washer machined for it. So I suppose I'll be purchasing a $360 super damper that I really don't need... FUDGE!
Old 04-01-2013, 07:41 AM
9-Second Club
Ed Wright's Avatar
Your engine will thank you.
Old 04-01-2013, 08:22 AM
That's what I was thinking. I'll be revving to 7000rpm so I guess its not a bad idea anyway.
Old 04-02-2013, 06:19 AM
leadfoot4's Avatar
It appears that you didn't understand that the ATI hub is for the ATI balancer.....
Old 04-02-2013, 06:54 AM
All it advertised itself as was an ATI replacement hub. I assumed it was a factory replacement hub manufactured by ATI. It even said it had the same 3 bolt pattern as the stock hub.
In either case, I'll be receiving my new ATI balancer and hub today and returning the other hub. No harm done!
Old 04-03-2013, 01:09 AM
fex77k's Avatar
I ran two of them, use the blue locktite they call for. Also you need a + torq bit, some thing like a 40 or 45 and a 12 point box wrench.
Old 04-03-2013, 07:26 AM
Got the blue locktite, got the 12 point, just need the a+.
Old 04-03-2013, 05:55 PM
fex77k's Avatar
Yea I had to chase down the snapon devil for a 40+ socket.
Old 04-03-2013, 06:05 PM
I must say, now that I have the super damper, I'm glad I got it. The engine goes in the car on Saturday morning. Not sure if I'll have everything ready for startup though. We'll see.
Quick Reply: Can I use a stock balancer with an ATI hub?
