Patrick G Solid Roller CHEAP Make Offer
Category: Engine - Power Adders
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): PA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Cam recommendation: (2000 F-body with 454 LSX block, ET Performance 240 heads with solid roller springs, FAST 90 intake, Automatic with 4200 stall, 3.73 gears, 1 7/8” long tube headers, no cats, 6400 rpm shift point, 6800 rpm rev limiter, 250-300 shot N2O)
254/272 .660”/.687” 113LSA +5 advance (with 1.7 ratio rockers)
Comp XE-SR/XE-SR lobes
4876R/4879R SR113LSA +5 advance (108 installed intake centerline)
Cam Valve Events 0.015 0.050 0.200
Intake Duration - ID 292 254 176 4876R XESR .660"
Exhaust Duration - ED 310 272 193 4879R XESR .687"
Lobe Center Angle - LSA 113 113 113
Intake Centerline - ICL 108 108 108
Intake Valve opens - IVO 38 19 -20 BTDC (- indicates ATDC)
Intake Valve closes - IVC 74 55 16 ABDC
Exhaust Valve Opens - EVO 93 74 34.5 BBDC
Exhaust Valve Closes - EVC 37 18 -21.5 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 118 118 118
Overlap 75 37 -41.5 degrees
