Need help with front end noise
Old 03-31-2013, 06:00 PM
wavebyby's Avatar
Default Need help with front end noise
Ok I bought a set of eibach pro lowering springs and just got a around to installing them I didnt have a problem with the rear at all and figured id tackle the front. Once i read a few things off here I took the hole front end apart and noticed that the lower ball joints where shot and the tie rods end where shot so i replaced them both , Heres the problem my strut hardware was very hard to get off and i had to cut the nut off on one side and had to cut the shock on the other which i then had to buy new shocks but didnt have much money so i bought these cheap ones for $60.00 each at auto zone for now which was im sure a bad idea but i wanted it back together now that its back together it makes a nosie when pushing the car up and down and worse when driven it , I took a video for you to hear it sounds like the upper ball joints are shot and need replacing now or the shock is hitting the top of the car ? ? ? .... let me know what you think
Old 03-31-2013, 06:01 PM
wavebyby's Avatar
doesnt seem to be letting me load the video let me try and down load to youtube and transfer the link
Old 03-31-2013, 06:16 PM
wavebyby's Avatar
http://www.youtube.com/watch?v=0iFTh...ature=youtu.be
Old 03-31-2013, 06:17 PM
Colbear96z's Avatar
Did you tighten up the upper shock bolt inside the mount all the way, when I lowered my car I didn't, and had a similar noise, had to take everything back apart and tighten it up!
Old 03-31-2013, 06:19 PM
Colbear96z's Avatar
Just seen the video, it actually is a lot louder then mine was, that's sounds freaky.
Old 03-31-2013, 06:22 PM
Colbear96z's Avatar
How did your shock mounts look? Did you replace tho? And the dog bone looking thing inside the mount?
Old 03-31-2013, 06:23 PM
wavebyby's Avatar
yea tighten everything up good , im not sure if its the shitty shocks bottoming out from being lowered or the upper bail joint i didnt replaced but im scared to drive it
Old 03-31-2013, 06:27 PM
wavebyby's Avatar
I didnt replace the strut mount because they looked good and i didnt have the $160 to replace them either , I wasnt planing on spending all this money on installing the lower kit everything i took off i put right back on except that little piece of rubber that sits in the strut mount i forgot them but those were only small pieces of rubber and wouldnt stop this noise once i take it apart again ill put them in
Colbear96z's Avatar
Might be dumb question but did you put the bump stop back on the shocks? It's a black plastic looking thing. Cylinder shaped that's slides on the shock.
Old 03-31-2013, 06:28 PM
metalmilitia606's Avatar
Sounds like a ball joint/blown shocks. Brand new shocks shouldn't bounce that much even if they are cheapos.
Old 03-31-2013, 06:31 PM
wavebyby's Avatar
that black plastic piece didnt go back on because it was cut in half but the rubber piece that slides on the shaft is on there , It could be a bad ball joint on the upper arm the lowers are all new , shock could be blown but i doudt it
Old 03-31-2013, 07:11 PM
wavebyby's Avatar
anyone else watch the video and have any ofther ideas on what it could be ?
Old 04-01-2013, 12:19 AM
wavebyby's Avatar
ttt bump
Quick Reply: Need help with front end noise
