Can someone confirm some 24x Conversion wire questions please.
I am in the midst of the Diy wiring and want to make sure I am on the right path. I have it mostly finished but wanted to make sure about the leftover wires. This is for a 97 Trans Am with T56 and no traction control.
LT1 Clear Connector:
I have #11 left and I believe I can delete it, is that correct?
LT1 Red Connector:
I believe I can delete #9, #12, #14, #23, correct?
LT1 Black Connector:
I can delete #2, #5, #14, #20, #23, correct?
LT1 Blue Connector:
Delete #10, #15, #20, #24 and #30, correct?
--Also, I have LT1 Red 2, Red 18, Clear 32 and Blue 1 as PCM ground to LS1 Blue 1. Do I hook all of these together and run a pigtail into LS1 blue 1?
--I have LT1 Black 15 and Black 31 go to LS1 Blue 57. Do I just splice these two together and run to LS1 Blue 57?
--Finally, LT1 Black 6 is supposed to go to three different LS1 pins, do I just split the Black 6 into three different wires so they can go to 3 different pins?
Thanks
Tim
LT1 Red Connector:
LT1 Blue Connector:
Thanks
Tim
Ok first please let me know what wires these are so I can help you. Any wire that states that 2 of the lt1 wires go into 1 ls1 wire than you just choose which one you like to put there, DO NOT SPICE. and Yes there are plenty of wires to delete.
just follow these instructions and everything will work out, do not cut anything off until you know everything is correct double and triple check
The efi connections wiring chart is what I used. The wires I posted are the ones I have left. I think I found a chart that answers my questions here:
https://ls1tech.com/forums/lt1-lt4-m...mpilation.html
Does this chart seem correct? If so, I think it should be a sticky...
looks legit, the ones I gave you is the efi connection chart, I used it no problems just make sure you get all the correct grounds, anything left over is just not used. You have to figure out your own location for the coil power and ground. I started on first try with a base tune.
Your grounds red 2, 18 and clear 32, and blue 1 can go into any of these on the LS1 pcm pinouts; blue 1, blue 40, red 1, or red 40. do not splice multiple ground into 1 pin whatever grounds are leftover are not needed
