z06 wheel question
z06 wheel question
I know this has probly been beat to death on here but don't have the time right now to wade thru all the enteries as I don't have a lot of time. So here is the question will a set of zo6 c5 style I think fit a 2000 camaro with now mods front ones being 17x9.5" in the front and the rear 18x10.5". Thank you so much for ur time in helping me with this. Need the quick answer because I'm suppost to be picking these wheels up on wendsday.
I've ran both the 275/40r17 front, 295/35r18 rear and the 265/40r17 front, 295/35r18 rear combos with no issues (at least 40k miles on the first combo, 10k on the second). The tires were Firestone Firehawk Wideovals. The 265s looked more correct (matched the rear's sidewall profile) but 275s were easier to find; they would have looked better paired with 305 rears.
I just got the factory C5 Z06 18X10.5 wheels for all 4 corners and found to my dismay that I will have to use at least a 1/2" hubcentric spacer and longer bolts.
right now the 18X10.5 rear wheels in the front barely clears the upper control arm, so using a spacer is a must at this point.
Wish I knew that earlier, I could have bought everything I needed beforehand.
