best way to clean lt1?
Old 04-01-2013, 05:34 PM
HarleyZ28's Avatar
Default best way to clean lt1?
So my motor is in need of a good cleaning. It has a msd opti on it. Im scared to take a power washer to this thing I dont want to mess anything up. Whats the best way to go about this?
Old 04-01-2013, 07:07 PM
myltwon's Avatar
simple green/degreaser and a rag is the safe way
Old 04-01-2013, 07:11 PM
F0x Slaughter's Avatar
^ +1 One.
Do not shove a hose under the hood and start spraying crap.
Old 04-01-2013, 09:25 PM
Spartan7's Avatar
Simple green on the block, brake cleaner on aluminum. WD40 works well for cleaning up plug wires.
Old 04-02-2013, 12:29 AM
MasterTomos's Avatar
I just use soap/water and a rag for most things. Just keep up on it and it doesn't really become that big of a chore.
Old 04-02-2013, 01:17 AM
popo8's Avatar
If the above options are not enough.. break out some towels, plastic bags, and tape, and tape off and protect all of the electrical and the the opti... and even then dont directly shoot any of them....
Old 04-02-2013, 05:06 AM
96capricemgr's Avatar
pressure washed under hood with Delco optis plenty of times.
Old 04-02-2013, 08:08 AM
97lt1camaro's Avatar
When I had my opti on the engine, I used a pressure washer on it as well numerous ones with no issues .
Old 04-02-2013, 09:25 AM
Village Troll
SS RRR's Avatar
Me too. That's all I ever did when living in an apartment and was adamant on washing the car once or twice a week. Still have the stock alternator as well. Key is to never directly spray the opti.
Old 04-02-2013, 09:38 AM
ThoR294's Avatar
I used simple green and a roll of shop towels from the zone...
Old 04-02-2013, 10:05 AM
sweetbmxrider's Avatar
The key is spraying at a 37-42* angle relative to the direction of the rotor position in no more than a 5mph head wind.
Old 04-02-2013, 10:45 AM
djjab57's Avatar
Simple Green and power washer here, Just dont soak the Opti. Never had an isuue
Old 04-02-2013, 11:07 AM
Village Troll
SS RRR's Avatar
Given the water pressure you would then be spraying a direct stream onto the opti.
Old 04-02-2013, 11:30 AM
lt4388stroker's Avatar
garden hose lol
Old 04-02-2013, 12:34 PM
Rob94hawk's Avatar
Took my hawk to the car wash in the middle of winter to wash away any salt underneath and it idled high for a week. I'll never do that again.
Old 04-02-2013, 01:36 PM
FormulaJoe's Avatar
I use a garden hose with my thumb over it, some soapy water and a big and small plastic brush. Power washer is overkill. The electrical connectors are made to keep water out, but I could see a power washer overpowering the connector seal. When I was learning auto body repair, during the detailing portion we learned to clean engine bays good. My instructor had seen power washers bug out car electronics before.
Old 04-02-2013, 02:23 PM
marc97taws6's Avatar
My engine bay was very dirty as I only cleaned it once, but simple green, some towels, and some elbow grease!
Old 04-03-2013, 10:11 AM
How else would you keep it clean?
Old 04-03-2013, 12:39 PM
HellTeeOne's Avatar
I use a paint-safe dereaser/all-purpose cleaner and a small electric pressure washer. I try not to spray the opti directly and have never had any problems. Mine has the vented opti though.
I also leave the engine running as well so everything dries faster.
Old 04-03-2013, 12:47 PM
Maybe it should be specifically said that many degreasers are bad for aluminum, like simple green. If left too long they will etch aluminum. If used quickly they are often OK.
Having the engine running helps too in that it is easier to clean grease and oil if hot.
Quick Reply: best way to clean lt1?
