HUC lobes
HUC lobes
I wanted to ask you guys opinion on the HUC lobes. Is there any loss of horsepower with these lobes versus the comp extreme energy lobes, i think they are called the xel lobes. I know the marine lobes like the wide open throttle more. I had a cam recommended to me using the HUC lobes but i heard i would lose some horsepower with this design and wanted to get feed back from yall.
Brain Tooley racing.
The HUC lobes are good to keep the valve train under control. Also helps parts live longer.
The smallest HUC is 294 @.006"/239@.05"/158@.200" with .365 lobe lift so 1.7 ratio is .621 lift.
Comparable XER is 287@.006"/238@.05"/159@.200" with .356 lobe lift so 1.7 ratio is .605 lift.
HUC lobe should make more power, they're also faster off the seat than LsL lobes and more stable.
The HUC lobe is what Erik used on the first NA 468 he built for me 3 years ago. 670rwhp 632rwtq SAE corrected on 93octane pump gas 11:1 compression, full exhaust and accessories. It was 696rwhp and 65xrwtq actual uncorrected.
I think they work. IIRC they were designed for marine applications that tend to run at elevated rpms constantly.
I wonder what lobes he used on my current build?? I have to ask him.
HUC lobes doing work! With BTR Platinum springs
LS Fest True Street Winner
FTP TURBO LS FOX LS FEST - YouTube
Need to show this to Jamie Mattingly...lol that thing is insane.
The FTP Mustang was fast, going 5.20's in the 1/8 with a air to air intercooler. But I just had a 6.0 with BTR/TFS 220 As Cast heads, LS6 intake and air to water intercooler run 5.17 @ 137 with the same cam!
Not bad for less than 400 lbs open spring pressure and stock rockers!
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
HUC Lobe Chart:
13045, adv 285, 231@.050 , 149@.200 , lobe lift .352 .598
13047, adv 289, 235@.050 , 154@.200 , lobe lift .359 .610
13048, adv 291, 237@.050 , 156@.200 , lobe lift .359 .610
13049, adv-294, 239@.050, 157@.200, .610"
13050, adv 294, 239@.050 , 158@.200 , lobe lift .365 .621
13051, adv-298, 243@.050, 162@.200, .627"
13052, adv 302, 247@.050 , 166@.200 , lobe lift .372 .632
13053, adv 306, 251@.050 , 169@.200 , lobe lift .372 .632
13054, adv 310, 255@.050 , 173@.200 , lobe lift .372 .632
13056, adv 318, 263@.050 , 181@.200 , lobe lift .372 .632
13057, adv-322, 267@.050, 184@.200, .632"
LXL Lobe Chart
13155, adv-266, 214@.050 136@.200, lobe lift .350, .595
13156, adv-270, 218@.050 139@.200, lobe lift .352, .598
13157, adv-274, 222@.050 143@.200, lobe lift .354, .602
13158, adv-278, 226@.050 147@.200, lobe lift .356, .605
13159, adv-282, 230@.050 15@.2001, lobe lift .358, .609
13160, adv-286, 234@.050 155@.200, lobe lift .360, .612
13161, adv-290, 238@.050 159@.200, lobe lift .362, .615
13162, adv-294, 242@.050 162@.200, lobe lift .362, .615
13163, adv-298, 246@.050 166@.200, lobe lift .362, .615
13164, adv-302, 250@.050 170@.200, lobe lift .362, .615
13165, adv-306, 254@.050 173@.200, lobe lift .362, .615
13166, adv-310, 258@.050 176@.200, lobe lift .362, .615
13167, adv-314, 262@.050 179@.200, lobe lift .362, .615
13168, adv-318, 266@.050 182@.200, lobe lift .362, .615
13169, adv-322, 270@.050 186@.200, lobe lift .362, .615
13170, adv-326, 274@.050 189@.200, lobe lift .362, .615
EPS Lobe Chart:
13116, adv 271, 222@.050, 144@.200 , lobe lift .351 .5967"
13117, adv 275, 226@.050, 148@.200 , lobe lift .352 .5984"
13118, adv 279, 230@.050, 151@.200 , lobe lift .353 .6001"
13119, adv 283, 234@.050, 155@.200 , lobe lift .354 .6018"
13120, adv 287, 238@.050, 159@.200 , lobe lift .355 .6035"
13121, adv 291, 242@.050, 162@.200 , lobe lift .356 .6052
LSL Lobe Chart:
13014, adv-265, 215@.050, 139@.200 .604"
13015, adv-269, 219@.050, 143@.200 .607"
13016, adv-273, 223@.050, 147@.200 .610"
13017, adv-277, 227@.050, 151@.200 .614"
13018, adv-281, 231@.050, 154@.200 .617"
13019, adv-285, 235@.050, 158@.200 .621"
13020, adv-289, 239@.050, 162@.200 .624"
13021, adv-293, 243@.050, 166@.200 .624"
13022, adv-297, 247@.050, 169@.200 .624"
13023, adv-301, 251@.050, 173@.200 .624"
13024, adv-305, 255@.050, 176@.200 .624"
13025, adv-309, 259@.050, 180@.200 .624"
13026, adv-313, 263@.050, 183@.200 .624"
13027, adv-317, 267@.050, 187@.200 .624"
13028, adv-321, 271@.050, 190@.200 .624"
13029, adv-325, 275@.050, 193@.200 .624"
*Thanks Brian, I Updated the list.
Thanks Brent, here are some more HUC lobes. I'm not sure why Comp doesn't have a single source that lists all HUC lobes. More like a Easter egg hunt... LOL
