turbo and th400 trans. line and cooler ?
Old 04-02-2013, 09:52 AM
SPOOLED UP's Avatar
Default turbo and th400 trans. line and cooler ?
What does everyone use for trans lines coming from the trans to the cooler?Steel line, half steel/half braided?I have -6 coming out of the trans but what next?ALso whats the best placement for trans cooler?dumIm turbod and have pusher fans with a Griffin radiator. SO wheres the best place for it on a f body?
Old 04-02-2013, 01:59 PM
stangtrader's Avatar
Im going to put mine infront of my rad but im also building a fox.as far as the lines I was going to use -6 push lock stuff on my set up
Old 04-02-2013, 10:19 PM
robsquikz28's Avatar
push loc are horrible and have set many cars on fire and crashed many cars because of them blowing off. I would NOT use them at all for trans lines especially if you have a big stall, trans brake and and revving the **** out of to build boost
Old 04-02-2013, 10:28 PM
55superbeetle's Avatar
Just trying to learn here, how much pressure is on the cooler circuit? Is it just a temp issue? I was under the impression that it was pretty low, didn't the factory use hose clamps over a flared tube? I know a guy that works for Parker and assures me it's pretty hard to get a push-lock assembly to fail if used right. I have used the stuff for years on oil coolers for vw air cooled builds. Normal to see 120 psi and 250 degree temps, never had one even show signs of failing. Cant speak for any other brands though.
Old 04-02-2013, 10:45 PM
Man-Crush Warning
Shownomercy's Avatar
Really?
I ran it on my last trans setup and it never leaked, hell I picked up teh damn POS trans by those lines.
With the correct fittings, summit rates their twist tite stuff at 250psi. Thats what I am running on my 80e setup.
Old 04-02-2013, 11:08 PM
Really?
REALLY????? YES go on YB and you can ask how many people have had it done to them! Its happened countless of times
Old 04-03-2013, 12:28 AM
This is good to know,i figured it wouldnt be an issue but id rather do it right the first time
Old 04-04-2013, 07:41 AM
ls1curt's Avatar
I made a custom mount on my set up. Its right behind the intercooler. I never see much above 180-190 during 80 degree weather. I have braided -6 all the way.
Old 04-06-2013, 06:07 PM
Boosted Firehawk's Avatar
bracket looks badass.
I like the -6 all the way front to back
Old 04-06-2013, 08:14 PM
adrynalinjunkie's Avatar
summit twist tite is made in China!!!
Fragola is made in the USA. Is it worth the leaks?
I hope you Chinese supporters are not leaking in front of me at the track.
Old 04-06-2013, 08:54 PM
True that!
Old 04-06-2013, 09:54 PM
Man-Crush Warning
Originally Posted by Boosted Firehawk
True that!
This whole subforum is full of cheap *** engines running cheap *** turbos on POS cars and you are gonna call me out for using an approved hose?
Old 04-06-2013, 10:21 PM
No I called you out for calling me a bullshitter!
They have caused many fires, accidents etc.
You said NO and I told you yes and where to go and research it.
Im just letting others know what CAN happen if using them for trans lines
Old 04-06-2013, 10:25 PM
Man-Crush Warning
Wait, are you robzquickz28....?
I did not call out anyone, I merely questioned it cause I was unaware, summit says it is/was NHRA approved for ATF.
Multiple personalities much?
Old 04-06-2013, 10:31 PM
Nope just the guy agreeing to the thread.
U called me out on that post. That was it.
Its all over YB and you can read it there.
Old 04-08-2013, 10:31 AM
Sarg's Avatar
Hmm my twist tite lines say made in usa on them. Fittings could be made anywhere. As an aside, I like the goodyear push on hose better than the fragola stuff. But putting both in a vice and pullingt as hard as I could I was not able to get either to back off. Maybe some of the earlier stuff was not as good?
Old 04-08-2013, 10:45 AM
Camaro9969's Avatar
Here's how I ran my cooler with -6 lines through the frame rail to keep it away from the hot pipes
Quick Reply: turbo and th400 trans. line and cooler ?
