Camshaft markings
Old 04-02-2013, 04:09 PM
joehernandez86's Avatar
Default Camshaft markings
So I just pulled out the cam on my l92 headed ls2. I'm not sure of the exact cam specs since I can't find the cam card would someone be able to tell me the specs and possibly what cam maker this is by these numbers?
http://s1320.photobucket.com/user/jo...tml?sort=3&o=0
Old 04-02-2013, 06:11 PM
3rdCoastPowerSports's Avatar
it looks like its 218/220 113LSA+3
maybe a Livernois Motorsports cam but not positive
Old 04-02-2013, 08:25 PM
Called comp cams they said it is a 231/239 113 the reason I was asking is because the cam has like 4 lobes that are pretty scarred up. I told them about it and they think its because of improper lifter preload that is causing te lifters to bounce when it's coming off the ramp. The lifter looked fine but cam was damaged. They said if I send it back they can regrind it for 125$ but it think at least 1 lobe may be to far gone.
Old 04-02-2013, 08:34 PM
wow, i was way off....
Sounds like its time to buy a new cam.
Old 04-02-2013, 08:41 PM
sabastian458's Avatar
That's interesting they said improper preload caused that. I have had 2 cam in 2 different engines have that same damages. One I did not setup, purchased it with the mods. The other I modded myself and was meticulous about making sure my preloads we're within factory specs for the lifters.
Makes me wonder...
Old 04-02-2013, 08:48 PM
I'm kind of curious too. I went with a different cam already but would like to know what happened to this cam. He also said something about ls7 lifters not being that great and that the stock l92 rockers could also be the cause. I will post pics up of the damage tomorrow.
Old 04-03-2013, 11:19 AM
Old 04-05-2013, 03:29 PM
LS1MCSS's Avatar
Originally Posted by joehernandez86
Buy a new one and use this one for a door stop.
Quick Reply: Camshaft markings
