victor jr install questions
I have an 01 z06 ls6 car that I'm doing a vic jr with an elbow on and ls2 throttle body. I have a question about hooking up evap, pcv, and vacuum.
The intake has one bigger hole towards the back and one smaller one on the side under the elbow. I'll just tee the back bigger one for the brake booster, map and another vacuum hose to it?
And on the evap and pcv, it have to be after or before throttle body? I have a catch can. Can i tee them both into the smaller hole by the mounting base? The fresh air inlet from the valve cover was capped off and used a oil cap filter to get fresh air in. Lmk if i need to do anything else and if this will work. Thanks! Will try to post pics
