Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
LSxTV - Corsa install on first Gen-V
Old 04-03-2013, 11:09 AM
9t8z28's Avatar
Default LSxTV - Corsa install on first Gen-V
Very good write up. I am surprised that a stock V with factory exhaust manifolds and cats, the Corsa exhaust still has the loose baffle rattle sound!
http://www.lsxtv.com/tech-stories/te...haust-upgrade/
Old 04-03-2013, 12:55 PM
kciaccio's Avatar
Thanks for sharing. I was on the line whether to spend the grand or not on a Corsa exhaust.
Old 04-03-2013, 01:04 PM
Stone17's Avatar
Get the Corsa. It's super quiet inside the car.
Old 04-03-2013, 01:48 PM
rand49er's Avatar
Holy crap! Can't really argue with dyno data. Adding 12 rwhp and 24 rwtq is nothing to sneeze at.
Personally, I did a Corsa after I'd had my car for 13 mos. and almost couldn't tell a sound difference. Then, I added L-Ts and am so glad I have the Corsa as it keeps it just barely civilized ... except at WOT.
Old 04-03-2013, 02:52 PM
garrettg's Avatar
Did only certain year v1's come with the exhaust brace?
Old 04-03-2013, 02:55 PM
garrettg's Avatar
Dyno numbers are a bit surprising given its the same size as stock and considered mostly a sound mod by most over the years, maybe there stock mufflers were not up to par and leaking or causing restriction?
Old 04-03-2013, 03:56 PM
rand49er's Avatar
Originally Posted by garrettg
Dyno numbers are a bit surprising given its the same size as stock and considered mostly a sound mod by most over the years ...
Totally agree. Even if it was 3" compared to OEM's 2.5", I'd find it hard to digest.
So, what's the explanation?
Old 04-03-2013, 06:52 PM
DACTARI's Avatar
Smoother pipes and joins? Freer flowing muffs? My exhaust guy said the stock pipes looked rough inside.
Old 04-03-2013, 08:21 PM
Fuzzy_Wuzzy's Avatar
inside I will agree that Corsa does not add a lot of sound inside the car (whats this with a "luxury" car and sound deadening). outside the car you would not mistake a stock exhaust for the Corsa.
Old 04-03-2013, 08:29 PM
I8URSVT's Avatar
12hp/24tq is nice for cat-back only! definitely better than i was expecting
Quick Reply: LSxTV - Corsa install on first Gen-V
