twin walbro 340s on stock rails,lines,return,regulator, no hobbs wired straight.
Old 04-03-2013, 05:56 PM
mrstepheneades's Avatar
Default twin walbro 340s on stock rails,lines,return,regulator, no hobbs wired straight.
Who has done this with no issues? Going on a pump gas 650 rwhp car. Thanks for any input...
Old 04-03-2013, 06:01 PM
1toofastlt1's Avatar
I run dual 255s on stock lines with out a hobbs switch. It drives fine
Old 04-03-2013, 07:14 PM
Thanks good to hear lol
Old 04-03-2013, 07:24 PM
Ryans99ls1's Avatar
my twin walbro's run all the time. I have a hobbs switch installed, wired and ready to go for long drives but i almost never switch over to it as i usually only bring the car out to run it.
Old 04-03-2013, 08:32 PM
703 CAMAROSS's Avatar
Twin 340's are way over kill in my opinion at that level I'm sure you could save the money and go with 255's unless your planning on going for more power. Twin 340's are good for 1300rwhp on pump gas...
Old 04-04-2013, 12:17 AM
beavis's Avatar
I have twin 340's that run all the time with no problem.
Old 04-04-2013, 12:37 AM
02LS1ram's Avatar
I have twin 255's Wired together. My fuel pressure never drops below 60 psi. Now the was with my procharger, we will see what happens with this new turbo kit I'm about done with.
Old 04-04-2013, 12:45 AM
TX RED's Avatar
twin 340 on e85 running all the time
Old 04-04-2013, 01:46 AM
a4ls2goat's Avatar
Twin walbros here. Seems like I cant get more than 60psi under WOT under boost though.
Old 04-04-2013, 01:52 AM
lemons12's Avatar
You guys are doing this with an other stock fuel system? Just the dual pumps and hotwire kits?
Old 04-04-2013, 06:04 AM
I plan for more power in the future. I'm a buy it one time kinda guy. That's why I'm also running fic1000cc injectors. Overkill but good for bigger and better things in the future. This is all on a s475 trans am. build thread link is in my sig which probably does not appear when I posed to here from mobile
Old 04-04-2013, 07:36 AM
Thanks everyone for the input
Old 04-04-2013, 10:17 AM
gpr
gpr's Avatar
How long have you ran it this way, and does it have any issues on hot days on a long drive?
Everyone in the fuel forum thinks running both pumps on all the time with a return fuel system will make it vapor lock and pumps fail. Because i have asked this exact same question. Setting mine up to use stock fuel line and evap as a return line with boost reference regulator.
Old 04-04-2013, 10:24 AM
not got it together yet.... installing all in next few days
Old 04-04-2013, 10:38 AM
gpr
gpr's Avatar
I guess i should have specified. For those who have ran both pumps all the time. How long have you ran it setup like this? Has it caused any issues?
I plan on running two 255l/h pumps all the time for e85. Was wondering if on long drives if i would have issues.
Old 04-04-2013, 10:44 AM
Ryans99ls1's Avatar
i sat in traffic for hours without an issue in 90+deg weather. been this way for a year
Old 04-04-2013, 11:16 AM
Moderator
denmah's Avatar
im running twin 400's in my stock tank.
stock everything 2000 silverado
i just ran a larger wire to the pumps, and put 80s in the stock fuel rails
Old 04-04-2013, 03:23 PM
Thanks again for the input!!!!!!
Old 04-04-2013, 04:44 PM
WSLN 6's Avatar
Twins full time here as well. -8 feed, -6 return with Aeromotive regulator. Oh, if an aftermarket fuel filter gets plugged, they will spray fuel out the top of the gas tank......lol
As long as the vent is decent sized, you shouldn't have any issues.
Old 04-04-2013, 05:10 PM
1BADAZZSS's Avatar
Triple pumps -10 feed. Single pump wired like factory function, other 2 on single hobb. I dont see why running all pumps on all the time if the extra fuel is not needed in vacuum. Only making the pump/pumps lifespan shorter.
Quick Reply: twin walbro 340s on stock rails,lines,return,regulator, no hobbs wired straight.
