Notices
WTB: T56 bellhousing, clutch kit, cam and valvetrain, large frame turbo
Old 04-05-2013, 01:34 AM
roastin240's Avatar
Default WTB: T56 bellhousing, clutch kit, cam and valvetrain, large frame turbo
Im looking for the following:
Camaro/Firebird style T56 bellhousing
Clutch kit new or used rated at 700 ft lbs or higher
Aftermarket cam for boosted application on a LQ4
Aftermarket push rods
Lifters (LS7 or aftermarket)
Aftermarket springs
ARP Head bolts and rod bolts (Need 2 sets of each)
Forged pistons/rods standard or stroked for LS1 block
Stock LS1 crank in good condition
Power steering pump with bracket (car type)
Alternator with bracket (car type)
Stock crank pulley (car type)
Corvette Oil Pan
Large frame (T4 preferred, might consider T6) Turbo, 74mm or larger Comp.
Large external wastegate
Electronic Boost controller
MAYBE a built forged short block or long block (Aluminum variant)
Aftermarket injectors (80lb/hr or larger)
Adjustable fuel pressure regulator
Let me know what you have, email at gattoni.john@gmail.com or text at 970-402-6118
Thank you guys and gals for the help!
Quick Reply: WTB: T56 bellhousing, clutch kit, cam and valvetrain, large frame turbo
