Pick my kit! Suggetions please!
I am looking for a kit for 50-75HP application. I am looking for reliability and something for street use, not track. I have stock bottom end 01 ls1 with mild cam and all bolt ons. Also have a 255lph fuel pump installed. Please suggest a kit!
thanks
thanks
Your going to be good with just about any system you want to put on the car. I would leave your self room to grow since you should have enough fuel to spray to around 550 whp.
I run a TNT f1 kit. It has been very good to me and was relatively easy to install. (wiring the window switch was probly the biggest pain) Also have a stock bottom end.
As the awesome folks at Nitrous Outlet suggested. Leave yourself room to grow.
That 50 shot you wanna start with is gonna turn into a 100 real quick. Then down the road 150 and so on.
Personally, I started with a NOS 5177 kit (number might be off)
Started with a 50 dry shot, worked up the ladder. Eventually upgraded my fuel system and got my current wet kit.
Now, I go to sleep at night dreaming of the day I can get a Nitrous Outlet "Black Widow" direct port kit.
Short version, save yourself time and money and get a good wet kit that can run a good size shot.
